Hinge Bolts Stripped on Clean Out Tray HatchHatch
ToddW850
Destin, Florida
Okay, for starters I'm a knucklehead. I'll explain.
I noticed when I lift the hatch for my clean out tray, that there was SOME wiggle from the left hinge. The hinge itself is solid. But the screws were a little loose. Tried tightening them, but they just spin, like it's stripped out.
So I go get 3 new longer SS Screws and 3 nuts. The plan is to drill all the way through and secure the new screws with the nuts. That's a solid solution! I did it with my anchor locker.
Here's the knucklehead part. I drill through, but I didn't realize the Dadgum hatch right there rests directly on the inside of the tray. Basically there is NO room for a longer screw OR nut.
DADGUMMIT!
Anybody happen to have a solution for this? Thanks.20140426_213853_resized_1.jpg20140426_213911_resized_1.jpg
Seadeals
Greenville, South Carolina
You could try filling the holes back in with resin. If you have some extra glass mat, layup a small square of cloth (or two) on the bottom side. Then drill new small pilots and install screws.
Speedling
Cedar Lake, IN
SS
fatter screw, not longer
And it's wood, so you can fill the holes with epoxy and re-drill them if needed.
ToddW850
Destin, Florida
Two great ideals @Seadeals and @Speedling . Also, I had thought of the fatter screws, but the hole is about the same size as the hole in the hinge. But I like the idea of filling it and drilling new holes.
Glassman
Redondo Beach, California, U.S.A.
D. All of the above
Or, many other methods. If you use resin or epoxy, try adding a tiny bit of chopped strand (fiberglass strands) stuff it down the holes with a toothpick. I know, easy for me to say, I could probably grab a pinch from the sole of my work boot. No fiberglass handy? use the toothpick! :cool:
