Completed I have 6 Wet Sounds out of my '18 242x
jacoviii
Independence Mo
255XD
I have 6 WS out of my '18 242x. nothing wrong with them. I just can't leave well enough alone. Only 20 hrs on the boat. So ... $360.
212xcarbon
Model # ?
jacoviii
Independence Mo
255XD
6.5" They might be the recon series. Or the same spec XS line. At work now but will look.
jacoviii
Independence Mo
255XD
Revo 6.5 RGB. The recon sounds fine but if I'm changing them for rgb I might as well go revo
jacoviii
Independence Mo
255XD
wet sounds XS-65ic-S 6.5
wet sounds OE-65ic-S 6.5
Wet Sounds XS-65ic XS Series Silver Cone 6.5" Coax open grille (Pair) The XS-65ic features a silver grille and silver injection molded composite cone with Wet Sounds proprietary rubber spider and surround, Nylas frame/grille. And Horn Flare ¾ inch aluminum tweeter and rubber magnet boot. Impedance: 4 ohms RMS Watts: 60 PEAK Watts: 120 Frequency Response: 40Hz to 20Khz Sensitivity: 89db at 1watt / 1meter Diameter: 6.8 inches w/grill (172.72 mm) Mounting Depth: 2.6 inches (60.04mm) Hole Cut Out: 5.0 inches (127mm)
jacoviii
Independence Mo
255XD
For some added info. same speaker new name
The RECON series will add great sound, RECON 6 speakers can be used with power built in to most head units in the industry today with only 60W of power needed, giving you the best sounding, and best valued speaker in Wet Sounds' history. Using a powerful 6.5" mid driver with a full rubber santoprene spider & surround suspension system, a light weight Nylas Nylon/Fiberglass Frame, as well as a injection-molded composite cone and high output 3/4" aluminum dome tweeter to give you the ultimate sound experience at a budget friendly price.
Impedance4 Ohms
RMS Watts 60 / Peak Watts120
Frequency Response 40Hz to 20KHz
Sensitivity 89 dB @ 1 Watt / 1 Meter
Mid Bass 6.5 inch Component Style Coaxial Speaker.
High Frequency.75" Aluminum Dome Tweeter
BigAbe75
Litchfield, IL
My wife would kill me, but just for curiosity sake, what would you take for 2?
BigAbe75
Litchfield, IL
2 speakes? or 2 pairs?
Sorry, 1 pair. To install in the midship location.
You think I can add those on my existing amps with no detriment to existing output?
jacoviii
Independence Mo
255XD
Yes you will need to run them in parallel with the stern speakers.
Advance
I’d like to do the same. Tired of not hearing the stereo while driving. Anyone have any pictures of midship install of 6.5”? I looked into a full speaker replacement along with amps. It doesn’t make sense, Wet Sounds can easily be $4,000+ and I am no audiophile.
Mredman86
I Could possibly be interested in 1 pair as well for midship on a 2019 242 Limited S, if they’d work with what’s already existing.
jacoviii
Independence Mo
255XD
Not sure what amp is on '19 242 Limited S? Is it the WS HTX6
jacoviii
Independence Mo
255XD
Sorry to all that were waiting on me. My wife had some input so it looks like I will be taking these off the market for now. We are going to be upgrading the subs for now and leaving the mids alone. If anyone is still in need of mid cabin speakers look here vvvvv
