kill switch replacement
RobertH
Sugar Sand
Tango Xtreme
Hi Folks,
Just wondering if it's an easy job to replace the kill switch on a Sugar Sand Tango ? Mine's next to the throttle - which looks simple enough to remove from the sidewall, just 3 screws - but I thought I'd ask before doing anything stupid. How do I remove this panel without causing myself problems with the throttle mechanism, etc ? Thanks
deubank1776
Ohio
252SD
I have seen a few youtube videos out there going in depth about the throttle control panel. I would assume it is real easy to replace a kill switch module.
RobertH
Sugar Sand
Tango Xtreme
OK I got the throttle housing off - the cables and controls are all mounted on a plate safely so that was easy. The kill switch is on a super short cable - there's zero play in the wiring at all which seems really stupid to me - but I should be ok to solder in a replacement. I can't hardly even get the ignition switchgear off to get any more length in the wiring, it's pretty dumb
deubank1776
Ohio
252SD
well best of luck
RobertH
Sugar Sand
Tango Xtreme
Yeah well I replaced the kill switch and....it still doesn't work. The old one even appeared to function fine when I tested it, so really that was a waste of time :(
If the switch itself isn't faulty, what else could the problem be ? Kill switch Ground wire not connected right to kill the spark ??
Advise welcome, thank you
deubank1776
Ohio
252SD
I would check for continuity.
sam green
Sugar Sand
Limited
Hi Rob
What is exactly the issue you are having?
