Newbie question - adding battery selector with no backplate
civics14
Hi all,
So, I picked up a 2016 Yamaha SX190 recently and decided to add a house battery. I bought the Seachoice 11501 battery selector. I noticed when pulling off the stock battery on/off switch that it had a back plate, but this new Seachoice doesn't have one.
I searched on the forum and can't seem to find anything regarding it. Is it safe to install this against the carpeted wall with no back plate?
Thanks in advance.
212s
1000 Islands
212S
:Welcome:
The carpet should be a decent insulator and not cause an electrical problem. However I would get a small piece of plastic and cut it to size and fit it in the back to close it off - or use the old one if possible.
With my luck there'd be a small piece of wire strand or other manufacturing debris in the carpet right where I install it, it bounces into the contacts, overheats and causes a fire. Me paranoid? Nah...
civics14
:Welcome:
Yeah, I was more worried about the fire aspect as well. The old switch is half the size of the new one. I will look for some type of plastic to cut out. Thanks for the response.
Ronnie
SF Bay Area
I would just cut and paint a piece of wood to mount the switch on. This is what I did for my onboard charger when I installed it next to the battery switches.
