Scarab 2021 255 twin 300 engines. P0325, C2111 error codes. Need help
255 Open ID
I presently have two errors with only 30hrs. Pulled out of storage and getting an engine light. I tried narrowing it down to the Port. But when I put my Candoo on the engine i get an error from both engines. One on the Port and one on the Starboard, Can anyone help clarify. Can i buy a knock sensor (Port engine) and cam position sensor (starboard) online ? Any suggestions as the dealer cannot see me for a month. Does anyone have an engine diagram so we can replace the sensors ourselves.
Second concern. Is this what you are supposed to experience in each of these modes. Boat is gutless out of the whole in Cruise and in Eco will only go to 40kph. When in ski mode it will come out of the whole hard and maintain 64kph.
gRobi
Germany erfurt
215 ID
You should start by unplugging the sensors, cleaning the plug. Klick it in again and delete the errors. May also have been unplugged with ignition on in the past. If the error stayesafter this procedure, try changing from port to starboard to see the error "moving" if confirmed, you can buy Sea-Doo sensors, as the are the same .
255 Open ID
I have narrowed it down by starting one engine at a time. The Port engine gives off the engine light. When i just start the starboard the engine light does not turn on. But when i hook up the Candoo pro. It throws an engine error to both engines.
gRobi
Germany erfurt
215 ID
So you have deleted the error and it comes back? Have you cleaned the connector?
255 Open ID
I cleaned cam shaft sensor and knock sensor with electrode cleaner. After 20 minutes on the water . Engine light came on. I now have P0325 and P0335 error. C2111 is gone
255 Open ID
So it's time to change them. Here is a good place to find your parts. https://parts.fwdealer.com/Login
That website did not provide any info related to engine parts. It was like pulling teeth from dealers for the part # . One dealer in Michigan was glad to help. I hope this helps anyone else on the forum
Knock sensor part# 462445
CSS part# 460686
Same for both engines
gRobi
Germany erfurt
215 ID
Sorry for the website, I thought it was detailed enough 😵💫 Hopefully changing the sensors will fix your errors.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
For future reference, BRP part numbers for the engine can be found here: BRP Parts Catalogs
Select Rotax>Rotax JPS>Two letter code starting at AA=2014>Engine HP.
