Shatty
- 195S
For the winter… do I have to shrink wrap if I have the OEM mooring cover? It’s the one that costs 900 with the ratchets. I know I would have to use the included poles thay keep it from accumulating snow or water. I’m in NY so we have cold winters. Does the boat come with antifreeze or another type of coolant? I heard I have to drain the coolant and use antifreeze and if it sits for a while I need fuel conditioner. Can I run it with antifreeze if it happens to be a nice day and I wanna take it out? Trying to avoid the high fees for winterizing by the marina. It’s also sitting on a lift. The one with 2 pontoon floaters. To drop I let them fill with water and to lift I run the air pump to flush the water from the floaters. I was told I could leave it on that for the winter. But check every once and a while to make sure snow is not weighing it down and still floating. I installed a ring cam on the dock so I can watch it live.
