05 AR210
Yamanator
CNY
Tige
Took my boat out for the first time today. The kid I bought it from had left it sitting so this may be a bad gas situation, however I don't think so. Both motors start up good and idle. Left motor revs perfectly. Right motor the throttle handle will fall back to idle if you don't hold it. At times it just hits hard out of the hole and no problems. Other times the right motor bogs badly. So I'm thinking it's either the cable or maybe a carb issue. I move the throttle with the motor off and it seems to articulate everything just as the left motor. Any ideas? I'm not really familiar with these two strokes. Once the boat is warmed up it seems to do that hesitation/bogging less but it still at times does it.
