mckev
- St Petersburg, FL
As the title says, I have yet to see any water from the exhaust pissers. The thermostat ones started working after I did thermostats and the engine flush.
I've don't everything I can think of:
Closed loop engine flush
Air blow out
Weed eater line (even traced it back to the exhaust hose to make sure the hose wasn't broken but I think I'd have bigger problems if broke )
Do these always flow when underway? Is there enough pressure? Seems it could be dumping out of the exhaust before it can spray out the side. Tempted to pull the hose on the exhaust when on the water and see if I get anything there.
Air blow out
