Rebel18
- SeaDoo
- Sportster
- PWC
I recently sucked up a large rock into my impeller on my 2003 seedoo sportster. I took her to the nearest jet ski/boat repair place, they said I needed to replace impeller which was fine, they proceeded to dismantle everything and in the process broke several bolts then returned the boat to my with everything in boxes all taken apart. Anyway I have put everything back together and would really like to see a picture of another sportsters rear gate area to make sure I didn’t miss anything. Also I have a coolant leak, is there a way to fix without taking out the bottom pan on the boat?
Thank you!!
Thank you!!
