jws123
- NJ
- SX
I have a 2004 sr230 with mr1 non ho engines that I picked up last season it was warm out today so I finished hooking up one engine it was pulled due to having water in it rings where stuck fires right up both engines appear to run ok. My question is how do I check the charging system on these to make sure both engines charge? Is it like a car where you should see 13-14v when running? if that is the case I don't even have 13v when running I didn't rev them tho this is at idle.
On a side note all of the padding under the hatch is falling off any suggestions on what to use to replace it?
