noviceboater
Just bought a used 2011 AR210. A car dealer took it in on trade-in, so they did a run through of it, but they are definitely not knowledgable.
I have had consistent problems with my port engine starting. First, when i turned my key, there is nothing that happened. My neighbor has a 190 and helped my check some of the connections to the starter and magically, the port engine started responding to key turns and starting immediately.
This morning I went out to the boat and neither key would turn, at all. I still haven't figured out why this happened, but the dealer had actually provided with replacement ignition switch assemblies. They mentioned they had to buy the whole assembly to get new black key moldings, but now wondering if they knew something else. Anyways, I replaced both of the assemblies and bam, once again, i am back in business. I took it out and ran it 2-3 hours today.
Then, on my way back in, i could not get my port engine to start again. It was the same engine as last night, but now, instead of 'nothing' happening, I am hearing a 'click'. It sounds like the battery is dead, but the starboard starts every time. It is not repeated clicking, just one, sometimes two clicks on key turn and nothing else happens.
As mentioned, I have replaced the ignition assemblies (also swapped them to see if the new ignition were the issue and it was not), cleaned and tighted battery connections (only has one battery but has a battery switch, thought that was odd), checked throttle in neutral and cleanout hatch killswitches.
What am I missing? Starter? Solenoid? Please give me a cheap/easy answer and I will buy you a beer.
