2012 Sea Doo Challenger Single Engine iTC Ski Mode
MikeInTampa
SeaDoo
Challenger
I am looking at a used 2012 Sea Doo Challenger 210, single engine 255 hp.
When the key turns on you can see the green Ski Mode lettering. However, when the Mode button is pressed, all that displays is LAP, CRUISE and ECO.
Is it possible for the boat to have iTC and not have Ski Mode?
Is something broken, or is the seller (non Ski Doo dealer) not showing the operation correctly?
Thank you,
Mike
I know my 2012 180 SE has the 'Ski Mode' Lettering etc on the dials, but doesn't actually have Ski Mode, I believe it was only on the SP model (the orange and black one), at least for the 180s
Nah, I think Scott is right, only with dual engines. I know my 210SE with twin 215's had it.
Our 2012 210 SE has it, and she's a twin engined boat.
you could give this a try if you buy the boat. No idea if it will work.
https://www.amazon.com/dp/B00AWPHRPE/ref=wl_mb_recs_2_title
Hi guys, I have a 2012 Challenger 180 (its a single engine, cant be other on 180 but just to clear things up) . I actually order and installed the ski module as per manual, unfortunately it does not work.. - bad luck, as i expected it to work as well when i bought the boat..
hope it helps some folks..
