2012 SX210, Alarms
Bud See
My 2012 SX210 is in the water tied to the dock and an alarm started going off. It had not been started since the day before. Tried turning off the bilge, cycling the key and starting the boat. Nothing worked and alarm continued. Had to pull the battery cable.
Anyone had this happen to them? Could it be the bilge pump or filters clogged?? Suggestions on what to look for would be appreciated.
Maybe it is your shallow water alert. Mine goes off often, silences by pressing W to T on the tach, can't recall which.
Thanks. I'll will try that.
@Bud See First off, welcome to the board, if it is your shallow water alarm, turn the engines off and after a few seconds that alarm should silence. if not lets start looking for something else
You can set it to 0 ft thru the settings. I set mine to that because I got too many false alarms with shallow weeds to make it worth having on.
