John P Jones
- Scarab
- HO Impulse
2014 Scarab 215HO - Engines were not running well when I attempted the Spring opening. Changed the plugs, oil and filter, flush and fill of the antifreeze. Cranked up the engines - very rough. CanDoo Pro scanner showed multiple misfires on both engines. Pulled the plugs again and activated them with the scanner - I had 2 bad coil packs. Replaced them and checked the spark out again - good spark (though something funky with the starboard engine cylinder #2 - will talk that soon). With spark - and plugs put back in - still running very rough. I pulled the fuel rail - found out that activating the fuel injectors via the CanDoo Pro doesn't exactly work - so I hung little bottles off the injectors and cranked the engines. I got spray, but it looked horrible. Removed the injectors and cleaned them using a DIY method I found on YouTube. Worked great. Port engine - runs fantastic now - no more faults - everything is cleared. Starboard engine is running a whole lot better - sounds like the port engine - but the CanDoo is still picking up a misfire on cylinder #2 - even though no check engine light and it's running smoother.
Now for the goofy stuff - and I hope someone can help with this:
When I initially activated the plugs via the CanDoo scanner, cylinder#2 would fire, then I'd hear a high pitch squeal (electrical, not mechanical) and the CanDoo scanner would lock up - I'd have to close out the software and reopen it. This happened consistently with Starboard cylinder#2 ONLY. But still no check engine light.
Any ideas on WHY cylinder 2 on starboard engine would do this?
