2016 Chaparral 243
dave06466
Chaparral
VRX
How can I tell if this is a 200 or 250 hp?
TYIA
External intercooler which you have. So 250.
Edit, autocorrect
Tow clamp diagrams and it happens to show the layouts.
Edit, autocorrect
Thanks appreciate the feedback one other quick question. I am not new to boating , but I am new to jet boats with those two engines. Do they need to be flushed out via the heat exchanger after use in the salt water?
Via the flush port only. Please go and get the operator's manual here: BRP GUIDES
Click Rotax > JPS > Letter code where AA=2014 onward so AF for 2016 > Engine HP
Everything you need to know about jet boats and yours specifically will be in there. Definitely read this. It will also describe the flush procedure. Make sure to follow it. Specifically, make sure to follow the order:
1. Engine on.
2. Water on.
3. Water off.
4. Engine off.
In that order. You can flood the engine if you don't.
The other important part is to NOT flush longer than 2 min at a time. You will overheat the critical carbon seal if you do. Frankly, less than a min is enough and avoids this issue entirely.
The "heat exchanger" is known as a ride plate. It has antifreeze in it. You need to replace the coolant every 2 years (green) or every 5 years (orange) depending on what you have in there. Or measure the specific gravity via a hydrometer to test its properties.
1. Engine on.
2. Water on.
3. Water off.
4. Engine off.
thank you appreciate all the info
In case you didn't realize, your boat has the same engine as Scarab. So if you look in that section of the forum, you may find lots of useful info. It's all the same.
