Leafjet
- Scarab
- HO Impulse
Having an issue with my 2016 Scarab 195 HOURS impulse.
Soon as I turn the key on I get an Ereverse error code and a very loud beep. Fault code shown is U0410. Been doing my due diligence over this last week looking over all the form pages and posts I can find on this issue and I’ve attempted the following fixes so far with no success. I also have a BUDS system and the COM light will go solid for a few seconds right when I turn on the boat but will then got to a few flashing green lights and or red flashing light and I’ve not been able make a successful connection (one the “read Data” lit up as the light had stayed solid green for a few moments longer then normal but light went away and no connection was made). I am using BUDS PowerPack P3.9.1
Reseated ECU connectors ( no sign of corrosion at all)
Changed out both engine bay fuse box relays for new ones
Changed 30 amp fuse box fuse out even though it tested good
Tested all fuses and all tested good with multi meter
Reseated all fuses in engine bay fuse box
Tested all fused and reseated fuses in helm fuse box
Tried a new fresh battery tested to be good and fully charged
Cleaned battery contacts
Checked for power at IBR 2 wire connector, tested good
Reseated IBR connector and inspected (no signs of corrosion)
Took apart IBR actuator and inspected motor, motor tested good when disconnected and manual operated with external battery
Checked IBR inline fuse located near battery disconnect
Can someone please confirm that my relay is in the correct orientation? The top left one can only go in one way but the bottom right relay can be flipped 180 degrees.
Not sure what to try or check at this point I’ve run out of ideas. Any suggestions or input is appreciated, thanks.
Also there is some sort of SCOM or extra module plugged into the diag port? It was just hanging out there not attached to anything. Tried connecting with BUDS with and without it attached.
		 yes I’ve traced through every article I can find. I’m at the point of it either being a bad ECU or bad INR and signs point towards INR I believe.
