2016 Yamha 212x
Dmitry
Questions about my 2016 212X Yamaha. I push throttle all the way gets in Limp mode in won't goo more then 5 miles? Check ingen is on along with a large being Sound. If you have any idea
what else’s was going on prior to the issue? Both engines or just one? Water coming out of the pissers? Overheat alerts? Voltage on your batteries? Is it only limp mode when you are full throttle? Were you surfing or have full ballast? Lot of information can be found by searching “limp mode.”
Both engine seems to have the same problem Driver side engine is worse. Water is coming out pissers and from underneath the prop jets. The water is hot which seems to cool off the engines.
Voltage: I have 3 batteries. 1 to start the engines, 2 in house. I noticed the battery drains faster than normal!
Limp mode: No difference if it's full throttle or not the engine RPM are not going up.
After tubing it went in Limp mode and then I shut off the engines and took longer then normal to start it back up. No water in Ballast.20230706_162923.jpg
