2018 SX 190
rayg1022
I have a 2018 SX 190 and I noticed when I'm cruising at low speeds for some reason the throttle control handle kicks back by itself for no reason? Any ideas on this issue?
It will do this even if the raised bucket height is within spec. You can tighten the amount of force required to move the lever to help deal with it. On the binnacle housing there is a small plastic panel on the rear side. Remove that panel and there is a throttle friction adjustment screw.
