Cdkjht1010
2022 Yamaha 212XE 24 hrs. on it. Second timeout this season and it keeps throwing a steering error take to dealer code. THe battery vlotage is 13.2V on both batteries and I cut the power to reset the system. It worked fine for about 10 minutes then shut down the port engine and same code appeared again and would not move the reverse bucket. I pulled it out to the water and reset the system again and both buckets moved and operated correctly. I had to reset the syetem 3 times before we got it out of the water safely. Bummer of a father's day..... It seems the the operation/mechanical parts work smoothly after reset but I am not sure what can cause this. Any ideas/help would be greatly appreciated before I take an hour away to the dealer.
