2023 222 xe sub woofer
toddgray519
Just picked up my boat and noticed the sub woofer isn’t working. I see a red and black wire only connected to the top of the subwoofer however I don’t see any other wires connected to it o felt the bottom of the sub woofer and felt that it have 4 holes for wires could someone provide me some photos of the wiring to their 10” sub woofer (wet sounds)
OK you need to go to the audio setup on the connext screen. You should be able to control the sub output zone 4
Yes I tried adjusting the zones that didn’t work
Unscrew the connector red,/black on the sub to check an see that they stripped the insulation off the wire.
Yes they did strip the wiring and it has a good connection
