212X first oil change
guppytrash
IL
I just changed the oil and filters on my 2015 212x.
Is there anything else for the first 10hr check?
And just making sure there is no grease needed for the newer 1.8l.
dansshin
Brooklyn Park, MN
Based on my 2013 212x user manual these are things you need to do for 10 hour maintenance.
- Spark Plugs: Check/Clean/Adjust
- Bearing housings: Lubricate
- Engine Oil: Replace
- Cooling water passages: Clean/Flush
- Sacrificial anodes: Check/Replace as needed
- Battery: Check
- Bolts and nuts: Retighten
guppytrash
IL
Thanks
Found the grease points!
Changed the plugs (just for grins)
All the items complete.
Ryan L Kula
Sheridan Wyoming
wich nuts and bolts are they referring too?
