212X is finally home and on the lift
Belleville_Boater
Belleville, MI
After long anticipation of the lake to thaw and picking up my new 212X, Friday April 17th was the big day!! Everything went great and it ended up being the nicest weather day of the year so worked out perfect.
Scottintexas
Corinth, TX (DFW)
it looks great, I wish I was bringing home a new '15!
SCSTWG
Syracuse, NY
Looks great and it looks like the Jeep is handling it good as well.
OperationROL
Knoxville, TN
Sweet!
Belleville_Boater
Belleville, MI
I'll get a pic of the interior when I get home and get it posted
Belleville_Boater
Belleville, MI
Yeah my Grand Cherokee looks like a gocart here but it handled it great, was about a 45 minute drive home all highway
Belleville_Boater
Belleville, MI
Here it is on my lift under the canopy, the tower won't go under so had to put it down which was a PITA but found an easier way to lower it without having to take off the center section, made my life much easier. I'm working on designing something even faster with a quick release (by the way im a design engineer by profession).
USMCDevilDog
Great looking boat! Yeah, definitely pita trying to get that tower down. Wish they would have put something together more innovative on the tower….
PEARCE
Kaufman, TX
Does your GC have a Hemi or the Ecodiesel? Great looking rig!
Belleville_Boater
Belleville, MI
What I found is if you just loosen the bottom rear fastener (about 4 thread lengths), then remove the bottom front fastener and the top tower fastener in that order while holding the tower up you can then rotate the center section back approximately 90deg till it hard stops on the tower base (it does not touch the hull or gellcoat at all). Do that to both sides then lower the tower, the tower should just clear the bottom rear knobs and the center sections as well. Then use a cushion spacer for the tower to rest on for the seats (I used a life jacket for now till I get a permenant solution)
Belleville_Boater
Belleville, MI
It has the V6 but it's the Grand Cherokee Overland 4x4 which has the Quadralift Air Suspension keeping it all nice and level. Pulled like a champ!
JimG
Lake City, Michigan
I will potentially have the same problem with my lift, so I am very interested in your solution for lowering the tower. One question -- what are you referring to as the "center section"? Is that the funny shaped side support for the tower piece?
JimG
Lake City, Michigan
Also, any chance you can take a few photos from the side so we can see how the pieces fold down on the tower base?
I was remiss not to mention in my first post that this is a damn good looking boat! When I originally started to shop for the 212X last year, when viewing on-line I liked the blue 2015 better than the black, but once I saw them both in person I changed my mind. Ultimately, however, I found a new 2014 that was way cheaper and went in that direction.
Belleville_Boater
Belleville, MI
Ahhh nice to see another fellow Michigander!! To answer your question, yes I was referring to the 'funny shaped side support' with the 212X markings as the removable center section. And I will take pictures of it probably tonight if the weather is nice. I've designed a potential quick release fix with pins which are at a shear strength of 4500 lbs with a safety factor of 2. Looking to boost that if I can but it's not bad. Also I'm designing it so there is little to no modification to the stock components of the boat. I'll keep you posted...
JimG
Lake City, Michigan
Thanks! A few photos would really be great, and a long term engineering solution would be awesome. It is good to know a design engineer!!
JimG
Lake City, Michigan
Any update on your quick release solution for the tower?
Belleville_Boater
Belleville, MI
Sorry Jim it took so long to get back to you on this. Yes the quick release solution works great, I'm very pleased with it! Takes about 15 seconds now to drop/raise the tower. I'm still looking to add one more piece which will serve as a rest for the tower in the lower position and it off of the rear seats but should have that by end of next week I think. I will definitely take pictures next time im out and get video of the process. I was strict on not modifying anything on the boat so that if you ever wanted to have the boat in stock condition you can.
JimG
Lake City, Michigan
Great news -- thanks for the update. I know thatI, and quite a few other 212X owners, are interested in seeing the final solution and following your lead here.
