TommyMcK
- SW Florida / Middle Chesapeake
- Wake
I have a 222XD with about 25 hours on it. The boat regularly throws a BCU error on startup. Often when this happens, the starboard engine will display in forward on the Connext, but sometimes not... The control is set to neutral on startup of course, so the BCU is somehow confused as to the position of the bucket. Other times, it'll throw the BCU error at startup but showing both engines in neutral. So far at least, it has always only happened when first starting out for the day. Subsequent stops and starts don't throw the error. I don't have enough data points to say for sure, but it seems like it only happens when I stop the engines with the wheel steered off to one side or the other. That may be a red herring...we'll see. It sometimes takes several tries to clear it, but it always sorts itself out in the end.
In any case, every electrical connection that I can find from the batteries to the bus bars and beyond are tight and secure so far as I can tell. Not necessarily expecting a solution here, but figured I'd mention it in case anybody else has something similar happen. This will be on my squawk list at the end of the season if I haven't resolved it by then... I don't plan on losing good boating by having it sit in a dealer's lot unless absolutely necessary.
I'll post with any updates...
