We launch an AR240 in Waukegan Harbor and go down to Navy Pier at least once a year and usually to watch the Chicago Air and Water Show (awesome view from the water). We have never had any problems, just always adjust boat speed to wave conditions and crew.
The lightness off the Yamaha does kinda of bounce off the waves compared to going thru them like heavier boats. I added Volvo trim tabs and push the nose down, and it makes a huge difference for comfort and speed.
I usually let my friends drive out on the lake so everyone in the boat can blame them for the rough ride.
Weight will be a factor, but I do believe the shape of the hull, especially the shape of the bow has more to do with a softer ride. Look at - lets say a Scout 210xfs center console. It weighs 1,980lbs - lets throw a 200hp Yamaha on the back - its weight still hovers around 3,000lbs - much less than your 242. Yet it cuts thru the water like butter.
I can't speak for the Great Lakes - but I do boat in a very very busy Ct lake. It can get extremely choppy on certain weekends. 2'-3' are not a an everyday thing, certainly not a welcomed site, but they are not uncommon. Those days are for coving out with friends, calm days are for playing.
My Yamaha handles big chop better than some, but not as good as others. Better than my buddies Crownie, much better than a friends big $$$ Malibu, but not as good as a Cobalt or a Bryant. And yes, as others have mentioned, we don't have trim, but you can ride the bow high using the throttles.
I've hated my boat on Erie both times I've taken it. Too small, and would much benefit from a rudder or "articulated keel" LOL to keep it going straight. My 0.02.
We probably saw you out there last year then! Chicago Air and water show is always great.
We try to hit up the Gary show as well, and THAT is another time to hit up the Portage side of things both before and AFTER the show! Gets wild waves right after the shows though!
I do wonder how much the new hull design helps in quartering or sideways waves. For me, these boats' tendency to get pushed around at the stern in rollers would really make me question buying one for use in water where such conditions might be pretty common. Oncoming or random chop is one thing, but if you might have miles and miles of 2 - 3 foot rollers coming in at a shallow angle - or worse a following angle - keeping the desired heading would get tiresome.
You know, it's just for these reasons that I think jet boats would be incredible as a catamaran. The inside straight walls would help keep them straight. Coming off of plane as well. Some day... Some day...
You know, it's just for these reasons that I think jet boats would be incredible as a catamaran. The inside straight walls would help keep them straight. Coming off of plane as well. Some day... Some day...View attachment 33982
I boat on Muskegon Lake a lot and whenever I see this ferry coming in I always think how fun it would be to drive under it. This thing can move too. Watch out if you're in the channel when it comes through because it flies, no wake or not.
It is a blast to ride on it up on the deck on a calm, sunny day. It really does move.
I have heard, but never personally had the pleasure, that it is absolutely torture on heavy sea days. They go about the same speed, glass or 6 - 8 footers. They have to in order to stay on schedule.
