252 FSH complete weight wet plus trailer ..
yam240sx
so i have a nissan armada with tow capacity of 9000lbs ... does anyone know the full wet wieght and the trailer combined numbers ? thanks
4,769lbs dry weight, 111 gallons of fuel = 666lbs. So with full tank of fuel it would be 5,435lbs. Add however much for gear and freshwater (if you want) and you’ll get your total for the boat. My assumption you would be approaching 5,600-5,800 lbs for the boat with gear/fuel. Depending on the build of the trailer I would assume 1200-2000lbs more.
thanks pal .. I think im cutting it close if the 85 % rule considered
