andrei_b
- Scarab
- HO Impulse
Hi Guys,
We've been enjoying our 2014 Scarab 195 HO Impulse for the last couple of years now, with just regular maintenance and no issues until the other day.
We had just left the dock and were idling out of the loading/unloading "no wake" zone, and no sooner did we get past that which is when I throttled up and within 1-2 seconds, I felt something letting go down in the hull of the boat. All manner of vibrations and rattling even at part throttle, so I turned right back around to head back in under idle power essentially.
We pulled the boat out of the water and the first thing I checked was the intake grate, which looked clear. I couldn't see anything stuck or blocking the impeller, so I went around the back to the jet pump discharge cone, where I could see some grasses stuck between the impeller and the nose cone area. Not being able to pull it out, we trailered it home.
Today, I was able to remove the reverse bucket and the jet pump discharge end. To my surprise, the impeller remained stuck onto the driveshaft. The grasses that were previously stuck now simply fell out, but I couldn't pry off the impeller from the drive shaft to save my life. It has maybe 1/2 in play to where I can pull it towards me, but that's it. It seems stuck on the spindles of the driveshaft.
Again, I was very surprised to see that the jet pump discharge nozzle had come loose from the impeller. The helpful video that @Luc Lafreniere had posted on removing the jet pump showed the impeller simply sliding off with the jet pump discharge end. It seems the jet cone end that threads into the impeller unthreaded itself, which then allowed the impeller to bounce around inside the housing, scratching up the wear ring and making horrible vibrations when I even touched the throttle.
Now my dillema: I'm unable to slide the impeller off the driveshaft spindles. It's likely with all the bouncing around in there, those spindles got damaged and now the impeller is stuck. I can also feel some side to side and up and down play on the driveshaft, not sure how much (if any) is allowed. Since this is as far as I got, I'm thinking I may end up having to replace the driveshaft (with the stuck impeller on it), and replace the jet pump components (impeller, wear ring, housing).
How difficult is it to replace a driveshaft on these BRP Rotax engines? Is this something anyone has tackled before and if so, can you point me to a how-to video? I snapped a few pics to show you where I'm at and the condition of the jet pump housing:
The scratches in the wear ring catch your fingernail pretty good, so I think it would be a good idea to just replace the entire housing with all new parts; the problem remains getting the old impeller off, which likely will require me removing (and maybe replacing) the driveshaft itself. I did remove the nose cone itself and everything in there looks perfectly good, all the grease is in there, no water or other contaminants. I just forgot to snap a pic. Also, that blue stuff on the threads is threadlocker, which I put on thinking I'd be able to just reattach the housing to the impeller, but no luck. The threads on the housing and also on the impeller may have gotten damaged while they were disconnected and the impeller was just bouncing around in the housing.
Would I also need to replace other parts while in there? Seals, carbon ring, etc.? What would you do? What would you advise I do? At this point, I'm as stuck as that impeller. The only other solution is to find a boat shop and have them do all this work for me.
I'd very much appreciate your thoughts, and thanks in advance.
