krypto69
- West Palm Beach, FL
- Other
- Other
HI
I have a 2023 AR220. In the water today and heard a pop then the starboard side engine vibrates like a broken engine mount. At very lows revs it seems ok but as soon as you give it a little throttle - it vibrates bad and doesn't sound right. So I limped back to the dock on one engine.
Any ideas? I took the cleaner port out and felt the blades and side walls and they felt okay - but not 100 percent.
If something got sucked up damaged prop. There was allot of foliage in the water. If that is what happened is the repair covered under the yamaha warranty?
