Georgia4Low
- FSH Sport
2024 Yamaha 222 FSH Sport E purchased new May 20th, 2024, and has 45hrs. Boat is showroom new condition and has been properly cared for and covered when not in use. 10hr service performed with Yamalube oil and Yamaha OEM oil filters, also jet pump shaft bearings greased at 10hrs. Boat has OEM color matched Marine Mat installed on rear swim platform. Also included are deep cycle marine house battery and marine cranking battery (both new May 2024), mounted fire extinguishers, anchor w/chain & 150ft of anchor line, oil change kit for both engines. Included is the optional aluminum tandem axle trailer that’s perfect for fresh and saltwater use, wheel bearings have been serviced as well. Reason for selling is that we are moving up to a 25ft FSH. Pictures taken 9/1/2024. Title in hand, local water test available with cash or cashiers check in hand. Maybe willing to deliver within reason or met up some where to lessen your drive. Asking $68,500 Call/Text 770-576-0533 leave message please.
Factory Equipment
-Trolling motor mount w/hardware
-Snap in marine mat
-Bow seating with cushions
-Bow filler/table with mount
-Engel cooler
-Owner’s manual, and other factory provided paperwork
-Twin 1.9L marine engine @ 200hp each
-Yamaha 5in Connext touchscreen 5in display
-9in Simrad chart plotter and graph
-6 speaker Hertz marine stereo system
-12 volt charging port & USB
-Phone holder w/wireless charging
-Underwater transom light
Additional Details: 22ft in length with 75 gallon fuel tank, dry weight on trailer approx. 4650lbs, 3 position no wake mode, cruise assist, raw water wash down, 26gal live well, insulated fish box, stainless tilt steering, drive by wire throttle system, fiberglass T-top with speakers, rod holders, spreader lights, map light, etc.
Factory Equipment
-Snap in marine mat
-Engel cooler
