Giliyo
- Baja
- Other
- Other
Hi All
I am working on a 90 sportjet in a Baja 1994
I have oil mix with water coming out between the jet drive and the power head.
I replaced all the seals on that drive. The input shaft shows some wear on the seal surface so I installed a shaft saver sleeve.
I still have water going into the gear area.
Any idea why ? Are thoes cases has an issue ? Otherwise it runs great good jet power. Any help is Appreciated
