Welcome to Jetboaters.net!
The A-70/A-75 inner slide, how the hell are you supposed to disconnect and reconnect the flexible brake line to the inner slide? This is on the 2009 MFI trailer with folding tongue.
Mine was too corroded and it loosened but not enough to separate and also would not thread back in, so I got a new assembly. That part is tricky. Also tricky was replacing the flexible hose from the new solenoid to the rigid tube in the trailer tube.
1. Disconnect steal brake line coil from rear wheel with 3/8 line wrench
2. Straight line and push forward
3. Leaving rubber brake line connected to the line, pull on it to help move the steel line forward
I did find, on pacific trailers, where they said white was ground. Question answered. New question, use DOT-3 or DOT-4 fluid? The previous owner said They never put any brake fluid in the trailer. Not sure what would have been standard in 2009 from Yamaha. I guess the answer is to push fluid though until it looks clean and there are no bubbles.
Yep. Bleed them through until good clean fluid and no bubbles staring with the left then the right. I use DOT3 high temp synthetic. Need a buddy to run the bleed valve if you are going to pump the actuator with a screwdriver.
I found one too checking tires before our last road trip to the lake in TN. Held my breath and pulled it out hoping it hadn’t gone through. Got lucky, but made darn sure the spare was fully inflated!
