Aftermarket speakers and control?
MajorBummer210
Taylor Lake, TX
Any recommendations on aftermarket replacement speakers to fit the existing holes?
Any recommendations on aftermarket radio sound system screen to go on the helm?
Not looking for tower speakers. Just want something good quality to replace the POS the boat came with
2017 AR210
JL Audio is what I'd buy if I was spending your money, lol.
2017 AR210
Basically anything is an upgrade from the stock speakers in an AR210. Top of the line is obviously JL and Wet Sounds. Kicker are good and well priced, from what you have.
Can't beat the Kickers for value, no matter I would strongly recommend adding an amplifier as well. The factory Polk isn't horrible, I would keep unless you have a good reason to change. The money for that should go towards an amp.
The AR series has the cheaper Jensen coated paper speakers...any decent marine speakers by JBL, Kicker, Polk, etc, would be a nice upgrade with an amp.
@MajorBummer210 what is is your budget? And what level of sound quality do you wish to achieve? That would help narrow down your choices.
Like @BlkGS said, JL Audio and Wetsounds are the top of the line brands. They cost more for a reason.
I've had Polk speakers in the cockpit and on the swim deck for years along with a 5 channel Polk amp. The 5th channel is for the sub in a ported box. I have a 2 channel amp for the swim deck speakers. Two years ago one of the swim deck speakers started to give out so it was time to replace. I went with JL's and they are well worth the cost. The sound and clarity is unmatched. I had the high end Polks, the MM series, still do in the cockpit, the JL's are just better. I also changed out my headunit from the original JBL CD player to a Fusion unit which probably had something to do with the improved sound too. For the most part you get what you pay for when it comes to sound quality. An efficient amp to push the speakers would be a wise choice too. Get whatever headunit suits you. I believe most of us here on the forum have gone with a Fusion like I did. Good luck.
I was referring to the Head Unit... it may be Infinity not Polk though.
