Colvin
- Scarab
- 255 ID
I purchased a used 2018 Scarab 255ID last year with engines at 112hrs and regular service records. I rode the boat twice and on the second ride it was determined a valve broke in the starboard engine at cylinder 2. The boat needed a full engine replacement which fortunately was covered under an extended warranty. Yesterday I took the boat for the second ride this season and the same codes popped up P0300 and P302 except in the port side engine. I pulled cylinder 2 plug and it was damaged at the end like the starboard engine was. I’m afraid it’s the same problem. Why would valves just break? I haven’t even towed a tube or wakeboard with the thing yet. Has anyone had this happen?
