LanierJet
- NA
Hi all,
I am a fairly new owner of a 2015 ar190. Got a great deal on it, and actually found it through these forums.
I am getting used to the jet boat, and have been out every weekend since buying it. We love it!
Question 1:
We boat lake lanier, which has some big water. I feel when I am running the boat, I am always over 6k rpms just to keep the cruising speed. This seems to be just the nature of the motor, but it's a big difference from the I/O I am used to. Running at 6000-7500 for a majority of the hours isn't bad as long as I maintain proper maintenance, right?
Question 2:
I noticed a little water in the ski locker. Not much, not even enough to cover the bottom. However, when I opened the drain plug, water was visible there, and the water wouldn't drain. In fact, some water spilled into the ski locker when I unplugged the plug.
Bilge pump is always on, and I know it works thanks to getting caught in a storm a couple of weeks ago. Is it possible some debri is down in the draining system? If so, is there a way to access that?
Thanks!
Question 1:
Question 2:
Thanks!
