viper15
- Wisconsin
I have a 2017 AR915 that has the factory forward swept tower and bimini. The very aft part of the bimini has a telescoping strut that allows for adjustment of the bimini up/down. The owners manual states that the lowest setting of the adjustable strut is to be used when towing a wakeboarder or skier. However, since new, I have been unable to adjust the bimini at all. The longest setting is all I can put the strut at. I'm physically unable to use any other setting of the telescoping strut without damaging anything. And in this position, I was fearful that the ski rope would contact the bimini. My first picture of the boat parked at the dock shows how high the aft portion of the bimini is as from the factory. Without any help from my dealer, I set out for a solution on my own.
My solution was to essentially cut one of the bimini struts a bit shorter. Instructions as follows:
- remove the bimini completely so you can work on it at a workbench
- you will be cutting the main aft support strut shorter, NOT the telescoping strut
- first, drill out the rivet holding on the strut mounting post using a drill bit just a bit larger than 3/16"
- remove the strut mounting post
- measure & mark 1" from the end of the exposed strut tube
- cut off the strut tube at the mark you just made; a plumber's copper pipe cutting tool works great for this
- reinstall the strut mounting post and use the hole in the mounting post as a guide for drilling a new rivet hole; drill a new 3/16" hole
- install a new 3/16" stainless steel rivet, & pop in place
- repeat process for the other end of the strut
- install on boat
- done
With the shortened main strut, I'm able to use the middle setting on the telescoping strut and get a nice tight fit on the bimini. If I really muscle it, I can even get to the shortest setting. But using the shortest setting is not really necessary.
Using the middle setting, you can see I have a nice bit of clearance to a ski rope - although this pic was taken in a yard setting. The following day I got a chance to make a couple of ski runs. I'm happy to report that the rope never came in contact with the bimini at all. It cleared when doing a deep water start, and while making my run and jumping from side to side of the wake, the rope always cleared the bimini by what I would guess is a good 6". Head clearance in the boat is great and the bimini looks much better on the boat.
Very happy with my solution and it was only a 1 beer job.
- install on boat
- done
