AR210 decal removal
KADay
I bought my AR210 new in 2019 and have just recently started thinking about removing the decals. If anyone has removed their decals on a black Yamaha, can you show me what it looks like afterwards?
That looks great! Did you order this stripe and add it yourself of take it to a pro? If you ordered it, do you mind to share the site? I'm thinking about a teal stripe.
It came with the stripe. That's just one of the two 2022 color schemes on the AR 190.
Yes I just did my boat Use Goo be Gone. let it sit for a few minutes. Then use a heat gun and start pulling away. Goo be gone sofens the glue underneath. The heat gun will make it easy to peel it off. Do not use a scuff pad,you will sractch your gel coat. If there is residue of glue after that be patient. You can use either mineral spirits and a rag, to get the rest.
Mine just pulled off. Took 90 seconds. A little goo gone for the outline and done. Ten minutes tops
Great I am glad that stuff worked out for you!
