Welcome to Jetboaters.net!
1998 MERCURY Sportjet 175, when to turn the ignition key to the on position, I heard a beep at the dash (normal), but I also hear a arc or snap sound from the engine at the same time, any idea what it could be?
Check the fuel pump and its circuit. That should go on when you turn to 'on', right? Not sure what else would be energized before you move to 'start'...
