srf32
- Seattle
- SX
So, we have been enjoying our new (to us) '06 SX210 for the past couple of weeks on Lake Washington - working out a few kinks, getting to know the boat and pulling kids on kneeboard and tubes. Overall, we've been loving it and have had zero problems with the boat.
However, it has become clear the boat is not keeping the battery charged. Was fully charged when we pulled off the trailer, showing 12.6-12.7 volts at rest. Have put about 12 hours on it since (per YDS) and have watched as the voltage has steadily declined by a tenth every other outing or so. Now showing 12.0-12.1 at rest and starting to trigger error code 19 (voltage issue) at random times.
Purchased knowing the charging system wasn't a strong point of these boats from reading these forums, but we don't have a big stereo or any other accessories using much power, so that's what led me down the path that something isn't right.
Started troubleshooting and determined both rectifier/regulators are good (by swapping) and the connectors on both are in good shape with liberal dielectric grease when disconnecting. Checked stator coil resistance and both sides were good and neither had ground shorts. Then put the voltmeter on the stator coils and started each motor and let idle. Bingo. Starboard engine showing 20.3 to 20.7VAC across the three combinations. Port engine showing 2.4 to 2.5VAC across the three. Then disconnected the round, 3 pin stator connector and it was in good shape as well. Took voltage at idle again and still bad. Don't see anything else to check without taking off the front cover to expose the stator.
So here's my question. Is there any reason not to just disconnect the rectifier/regulator on the port engine and run the rest of the season letting the starboard engine charge as best it can. I'll find a way to charge while docked. We have dual battery setup and never use the second battery, so we'll have backup. Our outings are not all day - usually 2-4 hours. I believe with the rectifier/regulator disconnected there should be little to no risk of hurting anything.
Don't really want to pull the boat out now to replace the stator as 1) we have a short season in Seattle, 2) just got boat in the lake 10 days ago due to dealing with an unexpected medical issue, and 3) we got lucky and have use of a slip at our club this summer.
Anyone do this before or have any experience with similar situation? Thanks in advance!
