It's not quite as simple as you think it is. Batteries are usually rated as Ah (Amp-hours). So for example, 12V 50Ah. This means your battery can provide 50 amps for one hour. Batteries sometimes provide "cranking amps" as well. Those are the batteries used to start a motor. That is the number of amps it can provide for a short amount of time (say 10-30 seconds). But you can't sustain that for long periods.
We're talking DC voltage from a battery and therefore, batteries can provide lots of amperage unlike AC circuits like in your house. Typical home circuit provides say 15 amps AC, so that's why you can't easily use a winch since they can pull easily 30-40 amps and much higher even. In order to provide that much amperage, DC electrical is used (or converters). a 12V battery can provide tons of amperage, especially for short bursts.
So I'm not sure what you're trying to do, but based on being on a boat forum, I'm guessing you're trying to figure out how long your battery will last with a stereo or other equipment?
lol
For that purpose, to get an approximate run time, you have to figure out how much load your boat will take. Let me give you my example:
The general rule of thumb I keep finding is take 10 x battery capacity in amp-hours and divide that by the load in watts. That gives you an approximate run time on the battery.
In my case, I have a single, 44 Ah battery. The load for the stereo in my case is a peak of 15 A (and after doing some research, it seems it will operate at around 10A (and 12V) because of the length of wires and such and not having it at max volume all the time). Assuming I also plug in my phone to charge, that outputs a further 2.4A (and 5V in this case). I have no idea how much amperage my dash takes, but if I had to guess, not that much so let's say 1A (and 6V? why not). That's a total load of about 10A*12V + 2.4A*5V + 1A*6V = 138W on average. So doing that math, 10x44 = 440 / 138 = 3.1 hours.
So theoretically, and based on various assumptions, my battery would last 3.1h before it's dead. Obviously not something you want to do. In the end, I installed a voltmeter that I can use to monitor the voltage of my battery as I use it. I make sure not to deplete it without running the motor for a while to charge it. I bought a cheap, USB port(s) that also provides a voltage reading. It's simple and gets the job done.
Clear as mud? Yeah, I know. Probably why nobody is answering! There is no simple answer. DC voltage is wonderful because it gives you LOTS of amperage/current, hence why they don't provide you with a current rating.
