Markk
- Grand Prairie 75054
- Limited S
I’m repairing screw holes left from previous owner. They had 5200 on them, but I wanted to fix them permanently.
Sanded surface to 400 before applying Spectrum paste. Took 3 coats to get holes completely covered.
After gel paste cured I sanded with 220/400/600/800/1000/1500. Followed up with fast cut polish on an orange pad and regular polish on the blue pad.
In hindsight, I stopped sanding at the 220/400 levels too soon as I feared I would sand through and reveal the holes I wanted to cover. This was my mistake. Lesson learned if you can see inconsistencies at the sanded stage, they will follow you to the glossy stage. Secondly, the inconsistencies were most visible when dry. When the surface was wet they were much more hidden.
