Blower and Connext
RoughRider
Falls of Rough, KY
Just started today. When I turn on Connext the blower comes on. And Vice Versa. 2015 242LS and never done it before today. [USERGROUP=9]@HELP[/USERGROUP] not serious but can't use stereo and that stinks
Sorry, not sure I understand. Connext, blower - where does the stereo come in?
Connext turns on stereo in float mode. So my issue is I dont need blower on in Float Mode
When I turn on connext my blower turns on.. this is normal. Then I just shut the blower off. Are you saying you cant turn the blower off ?
Mine too. Every time Connext starts up it kicks on the blowers. I press button to turn them back off.
I'm with @BigAbe75 & @Tms1224 . Thats how my 2019 works and note sure I would want it any other way? It will cut off automatically in 5 minutes OR I can turn it off manually anytime if I don't plan on cranking the engines.
When I turn blower off it turns Connext off.
Same. Connext on, blower on. Just turn off.
I hadn't ever had the issue before, but when I turned off Blower thru the Connext touchscreen I was good. My dumb butt kept cycling the toggle switch. :(. So I am good now, wasn't smarter than the equipment. Thanks for the responses and support.
