Boat Help
Ekim68
LS
I have an Yamaha LS 2000. The motor got flooded and now when I try to throttle it cuts out like it’s not getting enough fuel. The left engine runs fine. I’ve done compression test changed plugs, checked coil packs, and changed fuel filters. Would any have any idea on what it could be? Thanks
Flooded as in tried to start it and it had too much fuel or flooded as in water up over the engine? What does the oil look like?
Flooded with water over the engine. It’s a 2 stroke so the oil is mixed in the gas.
