Bow navigation light bulb type?
blacksapphirez
Charleston, SC
SX195
Does anyone know what bulb type is in the bow navigation lights?
It's called a Festoon bulb. Mine is a 31 MM. Strange looking bulb, about 1 1/4 inches long and pointed on both ends. I recently replaced all my bulbs with LEDs to reduce power consumption and because they are cool, literally and figuratively...
Anyway, the front navigation light was the last one I replaced and I had some difficulty there. The ones I found on Amazon were the correct size but I tried 2 brands and they made the green look blue. No good. I ended up paying $29 for one at West Marine which is a rip-off but even though it's labeled as a 31 mm, it's actually 33 mm and the cap wouldn't fit back on the light fixture. I tried one more Amazon bulb but had the same color problem so I went back with the West Marine bulb. To make it fit, I removed the light fixture from the boat and used a drill to enlarge the hole in the lower metal contact so the bulb would sit further down in the lamp. Problem solved.
