tdonoughue
- The Woodlands, TX 77381
So, our company had off on Tuesday (yeah, nice, huh?), so I went up and got my boat with the 8' beam out of the 8' 9" wide storage unit. The trailer was due for inspection. Took that and got that done. Then brought my baby home for a rare visit. While she was here:
1) Bled the brakes. Anyone know the bleed screw true size on these Shorelandrs? I used a 7/16", but even that didn't seem to exactly fit. And, no 11mm seemed to be just a little worse. Inspected all the hoses while under there.
2) Grease in all 4 bearings.
3) Tire pressure adjusted.
4) Completed second bilge installation (I had the pump in, the thru-hull, the hose--just needed to add the float switch and wire it all up). It even works.
5) Installed the new bimini top latches (the ones with the little push button instead of the pin--broke 2 screws in the process--talent).
6) Trimmed the tree under which the boat was sitting so it was clear of the tower.
7) Slowed all traffic on my street due to admirers.
8) Gave a really good rubdown with the Hot Sauce.
None of that may impress you; that is fine. Didn't impress me either. Anyway, I then took the boat back to the storage unit and (are you ready?) put it away with the tow vehicle (my wife's Q7) into that same 8' 9" space! There is not enough concrete to back in straight, so you have to pull up at 90 degrees and back around the corner into the space. On the 4th try and in about 30 minutes. Normally I just get it close and then use the Trailer Valet on the thing. But I was not in a hurry and decided to give it a try.
Didn't break the boat or trailer, either.
I take one gold star from petty cash, please.
