Whiskey
- Lake Tapps, WA
- SX
Thanks for the heads up. I've got a 18 and 17 on mine.Be careful with the list that shows all the cables. I found out that my 06 230 had two different length cables, one 18' and one 19'. I almost ordered what the list shows, but verified prior to ordering, and found that the starboard is 18' and the port is 19'. Look on the actual cables under the helm, about 1 or 2 feet from the end of the cable. There should be a part number on each cable. The last two digits are the length of the cable. Unless you see a reason to change, just find out what length you've got, and order a replacement. The cables I ordered are in my signature.
Yes jeez, apoplogies.Did you mean 18 and 19?
Looks like Babbits and Partzilla is out of the cables. I'm finding them on eBay and not much else.Be careful with the list that shows all the cables. I found out that my 06 230 had two different length cables, one 18' and one 19'. I almost ordered what the list shows, but verified prior to ordering, and found that the starboard is 18' and the port is 19'. Look on the actual cables under the helm, about 1 or 2 feet from the end of the cable. There should be a part number on each cable. The last two digits are the length of the cable. Unless you see a reason to change, just find out what length you've got, and order a replacement. The cables I ordered are in my signature.
