Ben Okopnik
- Tampa FL
- Other
- Other
- Other
Hi, all -
Newbie jet owner here, so still trying to figure out the basics; any help would be appreciated.
My little Rinker Rocket came with an obviously "after-market" control lever (can't say I think much of the quality, or the installation):
Now, in addition to being ugly, it also seems to have a tendency to drop into reverse - at least on land, where after trailering the boat, the lever is always pointing backwards - which is sorta nervous-making if you imagine it happening at speed in the water. The way it feels makes sense, more or less; moves very easy initially, then feels like I'm swinging a largish weight (smooth but somewhat heavy) as you move toward center, then very easy again.
So, some questions come to mind:
1) What does the standard control for this look like?
2) Did it have a neutral detent originally?
3) Would it make sense to gin up a couple of springs behind the plate that would center this thing by default?
4) Is there any sort of an adjustable brake on these cables?
I can clean up the way it looks - replace that plate with, say, some StarBoard and radius the corners, reposition the mounting screws, etc. - but I'm mostly focused on how it should function right now, and being unfamiliar with jets, I'd like to get some feedback from you more knowledgeable folks.
