Cavitation problem
John Mcpartland
Vancouver Wa
Could this be the cause of my cavitation?
This was from cutting off my nylon rope that was sucked up and melted then instantly hardened into a nylon bushing around the shaft
No. (IMO)
That damage to the shaft (these scrap/cut marks) would have no bearing on cavitation. Some impellers have cones to smooth the transition between the shaft and the impeller neck - but then many racers actually leave those out. I once inadvertently left an impeller pulling tool on the shaft (that was a Skat impeller, but same difference), run the boat all day long - didn't notice a thing (until I started looking for the tool).
However, any loss of sealant in the intake tunnel or between the pump segments that causes the pump to suck air will cause cavitation. Also - loss of impeller OD specs - "loose" fit inside the wear ring will cause cavitation.
So - the rope might have damaged/ bent the impeller blades (messing up the OD, outside diameter) or removed some sealant from the intake tunnel or between transom plate/wear ring/stator (pump segments).
I would start there - pull the impeller shaft and inspect the impeller/wear ring clearance (gap) and possible gaps/loss of sealant that need to be resealed. 3M 5200 is your friend there.
I just did the whole inside of the intake with 3m 4200, that is why the impeller was out. Good to know I don't have to buy a new impeller shaft
The shaft is fine I'm sure, and if you have it out - I'm sure it moves freely in the bearing inside the stator segment/cone, I really wouldn't worry about it.
The biggest danger with sucking a rope is - it can form a cocoon (spooling around the shaft) and literally destroy the (fiberglass) tunnel and the intermediate bearing int he transom - by expanding.
Obviously nothing to worry about in your case!
