Welcome to Jetboaters.net!
Nope, but that would look awesome. The only issue I see is the nav/anchor lights since it is a three-way toggle (ON-OFF-ON). How could you do that with a push-button? Only way I can think of is to have 2 switches... ON-OFF and ON-ON. Or maybe you could also have two ON-OFF switches to control the navigation (red-green) and position (white) lights separately, but that might require a bit of a change in wiring you risk forgetting to turn on the position light.
Thanks Nexus? Agree, I have looked for a ON-OFF-ON push button for the nav/anchor lights - without success. So fare the work around I consider is just installing a ON-OFF switch controlling both - so either all nav lights are off or on. In the rare case i just need the white anchor lights, I would just not plug in the red/green light-pole. Could that work? Or anything I missed?
