4x15mph
 - Downingtown, PA
I had water that would come into the engine compartment through the intermediate bearing assembly.  I think this is a common problem given the boats age and/or over greasing the bearing.
I found that when the engines were not running, water would trickle in to the compartment through the bearing (back on the engine compartment wall). If the engine was running, it does not leak.....
I tried to document what I could around the replacement of the assembly. Following is my cryptic summary for a 2001 LS2000. I purchased my replacement bearing assembly from Island Racing. This is a good time to replace the impellers if you are thinking about it as well as the impeller housing. I like the plastic liner option from Island Racing but neither my impellers or liners were in bad shape.
Directions/Steps
Directions/Steps
- Remove the couplet housing using a 10mm socket
 - Remove spark plug wires from the spark plugs and move them out of the way (no picture)
- Remove the exhaust outlet from the engine by loosening the clamp. This took some pulling and it helped to squeeze the rubber exhaust outlet below where it meets the engine. This helped to loosen it and with some prying of a screwdriver, this was removed.
 - Remove the grease line that is connected to the intermediate housing assembly. This pulls off with some wiggling.
 - Remove bolts from intermediate housing assembly which hold the assembly to the engine compartment wall.  (no Picture)
 - Mark the engine shim locations (4) by using a marker and marking the outline of the "V" opening in the shim. It is very important that the shims go back in the same place so that is the reason for marking them before you remove the engine bolts and shims. (no picture)
 - Remove the 4 engine bolts using a 12 mm socket. You may want to buy new motor mounts but you may have to spend more time making sure that the bearing assembly meets the engine flywheel to the exact specifications detailed in the service manual. My engine mounts were in good shape (fresh water)
 - Once the engine bolts are removed, slide the engine towards the front of the boat. Be careful as you work in this small space since you have oil lines, wires, etc.
 - I think it is necessary to remove the impeller from the back in order to get enough room to pull the bearing assembly forward and remove it. It is connected to the impeller and unless the impeller is separated, I did not have enough room with the engine in place to pull it away from the impeller shaft and pull it out. NOTE: This is a great time to check the impeller wear ring, the impeller (I had a ski rope wrapped around mine), etc. If these need to be replaced, this is the time to do it.
 - Start the impeller removal by removing the jet pump housing and reversal gate from the back of the boat.
- Remove the 4 (long) bolts
 - Remove the Steering link/cable Remove the Gate linkage (forward/reverse cable)
 - Remove the Water hose that is connected to the jet pump by removing the clamp. Note: This is a good time to think about removing the jet pump seal cone on the end of impeller shaft. This can be cleaned and regreased. You should also change out the rubber seal on the cone.
 - Pull out the impeller (see my write up in the member tips section). Use a lot of PB blaster if it is hard to get out and I used a long bolt/nut to pull on the impeller assembly... also lots of wiggling and patience. More patience.
 - Once the impeller is pulled out and separated from the assembly (or out entirely), you should be able to pull out the Interm Housing assembly from the engine compartment.
 - Here is the impeller and the housing assembly once it is out of the boat. Housing assembly is on the left and the impeller is on the right.
 - You then need to separate the black/coupler from the housing and then this coupler needs to be pressed into the new housing assembly. I had my local yamaha dealer do this for $60 (one engine/side) since this needs to be attached and removed precisely. You don't want this to be offset or bent in any way. See the yellow circle in the attached picture. This is the new assembly that you would buy and the other piece is what needs to be detached and then pressed onto your new assembly. Some people rebuilt the entire assembly by buying new seals, etc. It needs to be done exact since you would get vibration, leaks, broken drive shaft, ?? if it is not perfect.
 - I stopped documenting the process but when reassembling it is important to use the different Loctite products for the various bolts, etc.  You can see the specifics in the service manual.  Very important and you want to tighten all fittings using the torque specs in the manual
- Before reattaching the grease fitting to the new bearing assembly, you should either use a new tube that is clean or you should run new grease through the fitting. You will likely find older, hard grease in the tube that will prevent future greasing to be effective. I will still caution about greasing this assembly and you will know what i mean once you see how the grease can force out the rubber seal, resulting in the leak....
 - Double check all connections when you are done, especially anything to do with the oil injection system. Pay attention to the cooling system (pee holes) and the expected smoke when you first test drive and subsequent drives after. You just had the engine out.... I didn't have any problems but you certainly could if you aren't careful.
