Tommy Lee
- Scarab
- Other
Hello can someone give me some direction on this? 2014 Scarab 195, supercharged 4-tec, 136 hours. Yesterday my boat suddenly cavitated at around twelve miles per hour, but only briefly. I shut off the boat, then restarted it, and it hesitated for a bit and then operated normally, but the check engine light came on. After the check engine light came on the boat operated normally like I said.
Here is my problem, How do I identify the check engine code? I think this is an 02 sensor issue because this happened about three years ago and I replaced either the pre cat or the post cat 02 sensor I can't remember which but it fixed the problem. I thought the code comes up on its own on the display but I can't remember. Is there a procedure to pull up the check engine light stored code on the display?
