Check engine light on at 110 hours
Micki
195 G
Just bought a used 2015 195 and played on it for two days and 4 engine hours then got the check engine light after putting her in the water. Any help would be nice. She's at the dealership now for God knows how long cuz it takes then week I hear. Wondering if it was just a low charge on the battery at start up. Thoughts?
Dean P
Florida
Chaparral
VRX
Honestly, it could be anything. Did you notice any error codes? It'll always provide a 4-digit code.
Micki
195 G
Hi. No. Didn't see any codes. It did seem to sputter a bit. But not flashing, no codes and no oder or anything. I guess it did this one other time in it's lifetime but they didn't find anything and just reset the light. Frustrating tho.
jetboy
255 Open ID
If its the same as the 2016, the low battery charge light is separate from the Check Engine light and is located to the left on the speedometer cluster. The dealership should be able to get you straight, but for the error codes did you toggle through the display once the CEL came on? It would show fault codes as you are toggling through.
Micki
195 G
I didn't see a low battery light on. No sound or warnings. It's at the dealer but I also need to learn more about how to read these things and maintenance. I can't see anywhere, about a 100 hour service. Anyone have advice? It's at 110 hours.
Micki
195 G
Thx to all. Looks to be a bad sensor! I can handle that! 😁
Stantm
HO Impulse
What Sensor??? Don't leave us in suspense....
Micki
195 G
It was an 02 sensor. She's running better now. Thx all.
Now the button on the control handle is sticking. Wondering if I can just WD40 it a bit so I can get it into reverse. Thought??
